# JavaScript Scripting
This add-on provides support for JavaScript (ECMAScript 2021+) that can be used as a scripting language within automation rules.
# Creating JavaScript Scripts
When this add-on is installed, JavaScript script actions will be run by this add-on and allow ECMAScript 2021+ features.
Alternatively, you can create scripts in the automation/jsr223 configuration directory.
If you create an empty file called test.js, you will see a log line with information similar to:
... [INFO ] [.a.m.s.r.i.l.ScriptFileWatcher:150 ] - Loading script 'test.js'
To enable debug logging, use the console logging commands to enable debug logging for the automation functionality:
log:set DEBUG org.openhab.core.automation
For more information on the available APIs in scripts see the JSR223 Scripting documentation.
# Script Examples
JavaScript scripts provide access to almost all the functionality in an openHAB runtime environment.
As a simple example, the following script logs "Hello, World!".
Note that console.log will usually not work since the output has no terminal to display the text.
The openHAB server uses the SLF4J (opens new window) library for logging.
const LoggerFactory = Java.type('org.slf4j.LoggerFactory');
LoggerFactory.getLogger("org.openhab.core.automation.examples").info("Hello world!");
Depending on the openHAB logging configuration, you may need to prefix logger names with org.openhab.core.automation for them to show up in the log file (or you modify the logging configuration).
The script uses the LoggerFactory (opens new window) to obtain a named logger and then logs a message like:
... [INFO ] [.openhab.core.automation.examples:-2 ] - Hello world!
