Runtime Commands
 Examples
 Query an item's state:
 Changing an item's state:
 Get help for a command:
  Items
 | Command | Description |
 | openhab:status <item> | shows the current status of an item |
 | openhab:update <item> <state> | sends a status update for an item |
 | openhab:send <item> <command> | sends a command for an item |
 | openhab:items list [<pattern>] | lists names and types of all items (matching the pattern, if given) |
 | openhab:items clear | removes all items |
 | openhab:items remove <itemName> | removes the given item |
  Discovery
 | openhab:discovery start <thingTypeUID!bindingID> | runs a discovery on a given thing type or binding |
 | openhab:discovery enableBackgroundDiscovery <PID> | enables background discovery for the discovery service with the given PID |
 | openhab:discovery disableBackgroundDiscovery <PID> | disables background discovery for the discovery service with the given PID |
  Inbox
 | openhab:inbox | lists all current inbox entries |
 | openhab:inbox listignored | lists all ignored inbox entries |
 | openhab:inbox approve <thingUID> <label> | creates a thing for an inbox entry |
 | openhab:inbox clear | clears all current inbox entries |
 | openhab:inbox ignore <thingUID> | ignores an inbox entry permanently |
  Things
 | openhab:things list | lists all things |
 | openhab:things clear | removes all managed things |
  Links
 | openhab:links list | lists all links |
 | openhab:links link <itemName> <channelUID> | links an item with to channel |
 | openhab:links unlink <itemName> <thingUID> | unlinks an item with to channel |
 | openhab:links clear | removes all managed links |
 | openhab:links orphan <list|purge> | lists/purges all orphaned - one missing element (either item or channel) - links |
  Audio
 | openhab:audio play [<sink>] <filename> | plays a sound file from the $OPENHAB_CONF/soundsfolder through the optionally specified audio sink(s) |
 | openhab:audio play <sink> <filename> <volume> | plays a sound file from the $OPENHAB_CONF/soundsfolder through the specified audio sink(s) with the specified volume |
 | openhab:audio stream [<sink>] <url> | streams the sound from the url through the optionally specified audio sink(s) |
 | openhab:audio sources | lists the audio sources |
 | openhab:audio sinks | lists the audio sinks |
  Voice
 | openhab:voice say <text> | speaks a text on the default audio sink with the default TTS and voice |
 | openhab:voice voices | lists available voices of the active TTS services |
 | openhab:voice interpret <command> | interprets a human language command |
  Automation
 | openhab:script <script to execute> | Executes a script from the $OPENHAB_CONF/scriptsfolder |
  Firmware
 | openhab:firmware list <thingTypeUID> | Lists the available firmwares for a thing type. |
 | openhab:firmware status <thingUID> | lists the firmware status for a thing |
 | openhab:firmware update <thingUID> <firmware version> | updates the firmware for a thing |
