# Android App
The openHAB Android application is a native client for openHAB, compatible with phones and tablets. The app follows the basic principles of the other openHAB UIs, like Basic UI, and presents your predefined openHAB sitemap(s) (opens new window).
# Getting Started
This will only work on local networks and when the server does not enforce either authentication or HTTPS.
If it fails, you can click on Go to settings and manually enter the server settings.
- IP address:
http://192.168.1.3:8080 - Local hostname:
http://openhab:8080(depending on your network the suffix.localneeds to be added to the hostname) - Remote domain name:
https://myopenhab.orgfor an openHAB cloud account with myopenHAB (opens new window)
# Features
- Change items via NFC tags
# Permanent Deployment
This prefixes every item name, e.g. with the Prefix John the item AlarmClock becomes JohnAlarmClock.
# Alarm Clock
The openHAB app will send the next wake-up time from your alarm clock app to the server. The time is sent as a number containing the number of milliseconds since the epoch.
Example item definition:
Example rule:
var Timer timerAlarm = null
rule "Alarm Clock"
Item AlarmClock changed
if (newState instanceof DateTimeType) {
val epoch = newState.toLocaleZone.zonedDateTime.toInstant.toEpochMilli
logInfo("alarm", "Scheduling alarm for {} ({})", newState.toLocaleZone, epoch)
if (timerAlarm !== null) {
logInfo("alarm", "Reschedule alarm")
timerAlarm.reschedule(newState.toLocaleZone.zonedDateTime)
logInfo("alarm", "New alarm")
timerAlarm = createTimer(newState.toLocaleZone.zonedDateTime, [ |
logInfo("alarm", "Alarm expired")
timerAlarm = null
timerAlarm.cancel
timerAlarm = null
logInfo("alarm", "Alarm canceled")
# Call State
Example rule:
rule "Call State"
Item CallState changed
// No call activity
# Battery Level
Example rule:
rule "Battery level"
Item BatteryLevel changed
// Battery level is low
# Charging State
The charging state can be send to a String Item that contains the charger type or to a Switch Item, which is ON when charging, OFF otherwise.
// or
rule "Charging state"
Item ChargingState changed
# Wi-Fi Name (SSID)
Example rule:
rule "Wi-Fi name"
Item WifiName changed
# DND Mode
Example rule:
rule "DND mode"
Item DndMode changed
// DND mode is unknown
# Gadgetbridge Device Actions
Example rule:
rule "Gadgetbridge"
Item Gadgetbridge changed
# Device identifier
<Device identifier>| - Prefix the item names of Send device information to openHAB
- Use it as state on NFC tags
# Tasker Action Plugin
The variable %httpcode is returned by the plugin and contains the HTTP code returned by the server.
| Error Code | Description |
| 10 | Tasker plugin is disabled |
| 11 | The app couldn't establish a connection |
| 1000+ | A connection was established, but an error occurred. The error code is 1000 + the HTTP code, e.g. 1401 means Unauthenticated (opens new window). |
# Multi server support
- Quick tiles
- NFC tags
- Push notifications
- Tasker plugin
# Help and Technical Details
# My voice command rule isn't run
Please make sure that Default Human Language Interpreter is set to Rule-based Interpreter (http://openhab:8080/#!/settings/services/org.openhab.voice (opens new window)) and that the correct Item is selected at Other Services => Rule Voice Interpreter => Voice Command Item (http://openhab:8080/#!/settings/services/org.openhab.rulehli/select/ (opens new window)).
# Chart loading is too slow
If you experience slow chart loading times and your server isn't powerful, open Settings and disable High resolution charts to improve loading times.
# Icons look pixelated
# Trademark Disclaimer
