# Google Assistant Action
# General Configuration Instructions
# Requirements
- The openHAB Cloud Connector configured using myopenHAB.org (opens new window) (Items DO NOT need to be exposed to and will not show up on myopenHAB.org (opens new window), this is only required for the IFTTT service!)
- A Google account
- A Google Home/Nest Voice Assistant Device or the Google Assistant on your phone
# Item configuration
# Switch
| Supported Items | Switch |
| Configuration | (optional) inverted=true/false |
# Light
| Configuration | (optional) inverted=true/false(optional) colorTemperatureRange="minK,maxK" |
Dimmer { ga="Light" }
# Light as Group with separate Color and Brightness
| Supported Items | Group as light with the following members: Number or Dimmer as lightBrightness, Number or Dimmer as lightColorTemperature, (optional) Switch as lightPower |
| Configuration | (optional) useKelvin=true/false(optional) colorTemperatureRange="minK,maxK"Hint: if you do not set useKelvin=true then colorTemperatureRange is required |
Group lightGroup { ga="Light" [ useKelvin=true, colorTemperatureRange="2000,9000" ] }
Number colorItem (lightGroup) { ga="lightColorTemperature" }
# Scene
| Configuration | (optional) sceneReversible=true/false |
Switch { ga="Fireplace" }
# Valve
# Sprinkler, Vacuum
# Lock
| Configuration | (optional) ackNeeded=true/false(optional) pinNeeded="1234" |
# SecuritySystem
Switch { ga="SecuritySystem" [ pinNeeded="1234" ] }
# Camera
| Supported Items | String |
| Supported Items | Dimmer |
| Configuration | (optional) volumeDefaultPercentage="20"(optional) levelStepSize="5"(optional) volumeMaxLevel="100" |
# TV
| Supported Items | Group as TV with the following optional members: Switch as tvPower, Switch as tvMute, Dimmer as tvVolume, String as tvChannel, String as tvInput, String as tvApplication, Player as tvTransport |
| Configuration | (optional) volumeDefaultPercentage="20"(optional) levelStepSize="5"(optional) volumeMaxLevel="100"(optional) transportControlSupportedCommands="NEXT,PREVIOUS,PAUSE,RESUME"(optional) availableChannels="channelNumber=channelId=channelName:channelSynonym:...,..."(optional) availableInputs="inputKey=inputName:inputSynonym:...,..."(optional) availableApplications="applicationKey=applicationName:applicationSynonym:...,..."(optional) lang="en" |
Group tvGroup { ga="TV" [ volumeDefaultPercentage="20", levelStepSize="10", volumeMaxLevel="100", transportControlSupportedCommands="NEXT,PREVIOUS,PAUSE,RESUME", availableChannels="1=Channel1=NBC,2=Channel2=CBS", availableInputs="hdmi1=xbox:gaming,hdmi2=settopbox", availableApplications: "youtube=YouTube:Tube,netflix=Netflix:Chill" ] }
# Fan, Hood, AirPurifier
| Supported Items | Switch (no speed control), Dimmer |
| Configuration | (optional) speeds="0=away:zero,50=default:standard:one,100=high:two"(optional) lang="en"(optional) ordered=true/falseHint: if you are using a Dimmer then speeds is required |
With that you will be able to set up and use human speakable modes, e.g. "fast" for 100% or "slow" for 25%.
speeds will be a comma-separated list of modes with a percentage number followed by an equal sign and different aliases for that mode after a colon.
So here both "high" and "two" would set the speed to 100%.
Dimmer { ga="Fan" [ speeds="0=away:zero,50=default:standard:one,100=high:two", lang="en", ordered=true ] }
Switch { ga="Hood" }
Dimmer { ga="AirPurifier" [ speeds="0=off,50=mid,100=high" ] }
Blinds and simiar devices should always use the Rollershutter item type for proper functionallity.
Since Google and openHAB use the oposite percentage value for "opened" and "closed", the action will tranlate this automatically.
Rollershutter { ga="Awning" }
Switch { ga="Door" }
Rollershutter { ga="Garage" }
Contact { ga="Gate" }
Rollershutter { ga="Window" }
# TemperatureSensor
| Supported Traits | TemperatureControl (opens new window) |
| Supported Items | Number |
| Configuration | (optional) useFahrenheit=true/false |
Number { ga="TemperatureSensor" [ useFahrenheit=true ] }
# Thermostat
| Supported Items | Group as Thermostat with the following optional members: Number as thermostatTemperatureAmbient, Number as thermostatTemperatureSetpoint, Number as thermostatTemperatureSetpointLow, Number as thermostatTemperatureSetpointHigh, Number as thermostatHumidityAmbient, String or Number as thermostatMode |
| Configuration | (optional) useFahrenheit=true/false(optional) thermostatTemperatureRange="10,30"(optional) modes="off=OFF:WINDOW_OPEN,heat=COMFORT:BOOST,eco=ECO,on=ON,auto" |
To set the temperature range your thermostat supports, add the config option thermostatTemperatureRange="10,30" to the thermostat group.
To map the default thermostat modes of Google (opens new window) (on, off, heat, cool, etc.) to custom ones for your specific setup, you can use the modes config option on the thermostat group.
E.g. [ modes="off=OFF:WINDOW_OPEN,heat=COMFORT:BOOST,eco=ECO,on=ON,auto" ] will enable the following five modes in Google Home "off, heat, eco, on, auto" that will be translated to "OFF, COMFORT, ECO, ON, auto". You can specify alternative conversions using the colon sign, so that in the former example "BOOST" in openHAB would also be translated to "heat" in Google. For the translation of Google modes to openHAB always the first option after the equal sign is used.
By default the integration will provide "off,heat,cool,on,heatcool,auto,eco".
Group thermostatGroup { ga="Thermostat" [ modes="off=OFF:WINDOW_OPEN,heat=COMFORT:BOOST,eco=ECO,on=ON,auto", thermostatTemperatureRange="10,30", useFahrenheit=false ] }
Number ambientItem (thermostatGroup) { ga="thermostatTemperatureAmbient" }
# Sensor
# Addtional Information
add metadata via console:
# Two-Factor-Authentication
For some actions, Google recommends to use TFA (Two-Factor-Authentication) to prevent accidential or unauthorized triggers of sensitive actions. See Two-factor authentication | Actions on Google Smart Home (opens new window).
# Setup & Usage on Google Assistant App
- Set up the voice-activated speaker, Pixel, or Android phone (version 6+) with the same account.
- Start the updated Google Home app on your phone.
- Go to the settings part:
Account > Settings.
- Go to the home control part:
Assistant > Home control.
- Press the
+button.
- Select
openHAB.
- Login at myopenhab.org (opens new window) with your username and password.
- Allow Google access to your account.
- You will now be able to see your previously configured items and devices. Assign them to a room. Press Done.
- You can now control those devices from the Google Assistant.
# Example Voice Commands
- Turn on Office Lights.
- Set Office Lights to 35%.
- Open/Close the blinds
- Turn off Pool Waterfall.
- Turn on House Fan.
- Turn on Home Theater Scene.
# Frequently Asked Question
- Say: Hey Google, sync my devices.
If you expose thermostats make sure than you have:
- A Group item with the metadata value
{ ga="Thermostat" } - A Number or String item with the metadata value
{ ga="thermostatMode" }as part of the thermostat group - A Number item with the metadata value
{ ga="thermostatTemperatureAmbient" }as part of the thermostat group - A Number item with the metadata value
{ ga="thermostatTemperatureSetpoint" }as part of the thermostat group
Group g_HK_Basement_TSTAT "Basement Thermostat" { ga="Thermostat" [ useFahrenheit=true ] } Number HK_Basement_Mode "Basement Heating/Cooling Mode" (g_HK_Basement_TSTAT) { ga="thermostatMode" } Number HK_Basement_Setpoint "Basement Setpoint" (g_HK_Basement_TSTAT) { ga="thermostatTemperatureSetpoint" } Number HK_Basement_Temp "Basement Temperature" (g_HK_Basement_TSTAT) { ga="thermostatTemperatureAmbient" }- A Group item with the metadata value
- Remove all the metadata.
Switch TestLight "Test Light" { ga="Switch" }- Relink your account.
