# LIFX Binding
| Device Type | Thing Type |
| Original 1000 | colorlight |
| Color 650 | colorlight |
| Color 1000 | colorlight |
| Color 1000 BR30 | colorlight |
| LIFX A19 | colorlight |
| LIFX BR30 | colorlight |
| LIFX Candle | colorlight |
| LIFX Downlight | colorlight |
| LIFX GU10 | colorlight |
| LIFX Mini Color | colorlight |
| LIFX+ A19 | colorirlight |
| LIFX+ BR30 | colorirlight |
| LIFX Beam | colormzlight |
| LIFX Z | colormzlight |
| LIFX Tile | tilelight |
| White 800 (Low Voltage) | whitelight |
| White 800 (High Voltage) | whitelight |
| White 900 BR30 (Low Voltage) | whitelight |
| LIFX Candle Warm to White | whitelight |
| LIFX Filament | whitelight |
| LIFX Mini Day and Dusk | whitelight |
| LIFX Mini White | whitelight |
| Thing Type | On/Off | Brightness | Color | Color Zone | Color Temperature | Color Temperature Zone | Infrared | Tile Effects |
| colorlight | X | X | X | |||||
| colorirlight | X | X | X | X | ||||
| colormzlight | X | X | X | X | X | |||
| tilelight | X | X | X | X | X | |||
| whitelight | X | X | X |
| Channel Type ID | Item Type | Description | Thing Types |
| brightness | Dimmer | This channel supports adjusting the brightness value. | whitelight |
| color | Color | This channel supports full color control with hue, saturation and brightness values. | colorlight, colorirlight, colormzlight, tile |
| colorzone | Color | This channel supports full zone color control with hue, saturation and brightness values. | colormzlight |
| effect | String | This channel represents a type of light effect (e.g. for tile light: off, morph, flame) | tilelight |
| infrared | Dimmer | This channel supports adjusting the infrared value. Note: IR capable lights only activate their infrared LEDs when the brightness drops below a certain level. | colorirlight |
| signalstrength | Number | This channel represents signal strength with values 0, 1, 2, 3 or 4; 0 being worst strength and 4 being best strength. | colorlight, colorirlight, colormzlight, whitelight, tile |
| temperature | Dimmer | This channel supports adjusting the color temperature from cold (0%) to warm (100%). | colorlight, colorirlight, colormzlight, whitelight, tile |
| temperaturezone | Dimmer | This channel supports adjusting the zone color temperature from cold (0%) to warm (100%). | colormzlight |
The color and brightness channels have a "Power on brightness" configuration option that is used to determine the brightness when a light is switched on. When it is left empty, the brightness of a light remains unchanged when a light is switched on or off.
The color channels have a "Power on color" configuration option that is used to determine the hue, saturation, brightness levels when a light is switched on. When it is left empty, the color of a light remains unchanged when a light is switched on or off. Configuration options contains 3 comma separated values, where first value is hue (0-360), second saturation (0-100) and third brightness (0-100). If both "Power on brightness" and "Power on color" configuration options are defined, "Power on brightness" option overrides the brightness level defined on the "Power on color" configuration option.
The temperature channels have a "Power on temperature" configuration option that is used to determine the color temperature when a light is switched on. When it is left empty, the color temperature of a light remains unchanged when a light is switched on or off.
MultiZone lights (colormzlight) have serveral channels (e.g. colorzone0, temperaturezone0, etc.) that allow for controlling specific zones of the light. Changing the color and temperature channels will update the states of all zones. The color and temperature channels of MultiZone lights always return the same state as colorzone0, temperaturezone0.
LIFX Tile (tilelight) supports special tile effects: morph and flame. These effects are predefined to their appearance using LIFX application. Each effect has a separate speed configurable.
# demo.things:
# demo.items:
// Living
// Porch
// Ceiling
// Kitchen
# demo.sitemap:
    Frame label="Living" {
        Switch item=Living_Color
        Slider item=Living_Color
        Colorpicker item=Living_Color
    Frame label="Living2" {
        Switch item=Living2_Toggle
        Slider item=Living2_Dimmer
    Frame label="Porch" {
        Switch item=Porch_Color
        Slider item=Porch_Color
        Colorpicker item=Porch_Color
        Slider item=Porch_Temperature
        Slider item=Porch_Infrared
    Frame label="Ceiling" {
        Switch item=Ceiling_Color
        Slider item=Ceiling_Color
    Frame label="Kitchen" {
        Switch item=Kitchen_Toggle
